- Bedford UK
I've been fiddling with the R4 Gordini. Previously I had the thing running reasonably on the original distributor but it wouldn't run well around town and increasing throttle at high load would make make the engine slow down.
I decided it was probably worn ignition timing causing the problem so bought a shiny programmable distributor from 123-tune. The car is now a lot better around town, but starting is rubbish and the engine dies if I press the throttle too quickly.
Does that sound like too retarded to you too? Advancing does help but I'm nervous that I need to run over 40 degrees max advance to make it happier which seems way too much. There is no sign of pinking when I advance the ignition more than I'm happy with.
If the engine was too retarded it ought to work predictably just a bit slower. The engine shouldn't die. I'm wondering if I have a fuelling issue or a weak spark issue. I've changed the coil and plugs in the last week. Plugs were on the white side of normal.
Any thoughts anyone? I suppose I could bung the original distributor back on and record the advance curve with a strobe and use that as a starting point.
