Picking up the thread that veered off from '950cc valve clearences', I am still trying to work out what the noise is.
Not valve clearences. Not pinking. Not leaks from the exhaust (at least i can't find any), plugs all tight (and colour good)... I suspect small ends because of the engine's history (I was told that the big ends were recently renewed due to a dry sump issue), but i don't want to have to get the engine out unecessarily (but also i don't want to wreck the engine driving it about listenening to it self destruct!).
Here's a link to the engine running. Tappets a little noisy but the engine is cold (hence the hesitation when i pull the throttle: i have the choke in to reduce the revs and make the thing audible), but you can hear the clatter as the engine accelerates. It does the same pulling away or while cruising at speed. No oil pressure warning light, no lack of power through the rev range up to over 100kph. I can get light pinking foot to the floor in 4th gear at medium speed.
mojobaby tells me that pulling off the sump will be a bitch with the engine in the car... is this because the anti-roll bar and cross member get in the way? Can i just remove them first and put the front of the car on stands so that i can get at sump to remove it and get at the crankshaft? I'm still waiting for the Haynes manual to arrive ;-)
All suggestions received greatfully!
