Cylinder Sleeve Seals
S-Car-Go
Knoxville, TN, USA
Are the paper gasket sets for the bottoms of the cylinder sleeves still available in the UK? I am very much in need of some for the 1.3 litre engine.
Pretty sure diameter is different if you buy a complete bottom end gasket set made by payen it will come with liner seals in all thickness
810 engine was 1289 cc used in R10 R12 and R5 1975 -1980/1
Guess some of the continental suppliers should have them listed
The picture may not be the actual item, it says non binding sample image above the picture.
Best to email and ask them about what it contains.
Just done a full rebuild on a 1289 they do indeed come with a full gasket set in 3 thickness colour coded I used red for maximum liner projection
Green .10 mm blue .08 mm red .12mm. Must say it takes a while to get the progressive step from cylinder 1 to 4
I am happy to report that I was able to find workable gaskets. If they don't come with the p & c set, sadly, one can expect to pay about £ 12.50/gasket over here. C'est la vie.
