A bit more info and clarification on P43t, P45t & yellow covers:
P43t and P45t refer to the base only and have nothing to do with the shape of the glass or whether the bulbs are halogen/tungsten/etc.
P43t is the 3-prong base (see Andrew's description above). (Not to be confused with BA21d 3-pin bayonet base bulbs, as fitted to most French cars of the 1950s, normally 36/36w or even less).
P45t is the round base, (as in R4, 2CV etc). P45t is available with different glass shapes, tungsten or halogen, 6, 12 or 24 volt, from 40/45w up to 100/130w. Each of these variations has a different number (such as 410, 485, HB12, etc) but all with this round base are P45t. As Andrew has already said, the halogen versions were introduced later, as an 'upgrade' option.
Here are three 12v P45t bulbs that are commonly fitted to R4s and many other European cars of the 60's/70's/80's:
"410": 40/45w tungsten with clear glass.
"411": 40/45w tungsten with yellow glass.
"HB12": 55/60w halogen with clear glass (with a dipped black end).
"Selective Yellow" glass covers are available for P45t (& P43t) halogen bulbs but they are not universal: The part of the bulb that the yellow cover attaches to is not a standard size across all bulb manufacturers so a cover from one manufacturer may not fit a bulb from another. (This is why I sell the compatible bulbs and yellow glass covers together).
"485" 80/100w halogen can be fitted in place of 'standard' P45t bulbs but modifications will normally be necessary due to the additional load on the wiring, switch, etc. Also these are not legal for "road use" in some countries. Although the yellow glass covers will also fit 80/100 or 100/130w P45t bulbs (of the same make), I suspect that the additional heat that higher wattage bulbs generate might cause problems with cracking covers or shortened bulb life.
The reason that the French government introduced compulsory "selective yellow" headlights was apparently because, at night, the human eye is better at picking out shapes, outlines, etc, in that particular shade of yellow than in the light of 'normal' headlights.
