Hello. Long message alert!
I am trying to find more information about various Renault 4 differences. Was wondering and hoping that some of you may know /have opinions on different engine traits, and also chassis dimension specifics. I would be so grateful for any information/opinions from people that are in a position to give it
Questions are below; but my background:-
In the past I have some trans-global trips in Citroens , the 2CV, the (original) DS etc. From behind what was the iron curtain a few years after the wall came down; to Asia; New Zealand; and African countries. One of my potential future journies maybe in a Renault 4 /F6; and I am considering getting an R4 anyway; trip or no trip.
(1) The four wheel drive system & chassis lengths. Did Sinpar & the other 4WD makers make 4WD options on the long chassis as well as the 'normal' chassis? IE is there a long chassis 4WD system too; in addition to the regular chassis 4WD system?
I have heard today that 4WD R4's were also made in Scotland for utility service businesses. I naturally assumed that this meant "vans"; but I don't know. Does anyone? And if so were they long or short chassis/wheelbase vans? It is possible that " normal cars" were converted too; to ferry staff around. (Just like the Citroen 2CV Sahara was made for--four wheel drive and two engines).
The extra length in the "Long" chassis for the F6; which I have documented as being 120 mm longer than the standard chassis; is shown in my diagram as being in the section towards the rear of the floorpan. Ie in front of the rear axle. (This is in addition to the extra length added on the back)
Also thewheel base is listed as being longer.
This therefore means that the propshaft would have to be longer; and there therefore must be two different lengths of propshaft for the 4wd system(s). Does anyone know definitely please; how many 4WD system and lengths there are?
That leads me on to the next question. If people have adapted the 4WD system from a short to long chassis; have they "just" lengthened the propshaft; or has anyone moved the whole rear axle/components forward?
(2) Engines
I read the 1108cc engine has a lower rpm for both power and torque compared to the smaller engines. Does this mean the smaller sized engines are much more freely revving; and therefore perhaps better suited and balanced to harsh use?
I am aware the 956cc unit is derived from the 1108 and presumably has the same characteristics. As my background in cars is a Citroen background; this flexibility and "revability" to me seems a useful trait.
(3) I have heard that these engines had problems accepting four star fuel at the time; and have problems with unleaded. Mostly the 1108cc engine I thought; but today I was told that all R4 engines did not get on well with unleaded. What are peoples findings? Again coming from Citroens where there is no problem at all with unleaded fuel; this was a surprise and a shock to me. I assumed Renault, being a French car maker too would be similar.
(4) I was intending to run the original size engine. The theory being light weight and relatively understressed; and so therefore hopefully reliable. I know some people put bigger R5 engines into R4's. Are these are more reliable with fuel unleaded etc etc?.
I have had Citroen mechanics that have been fine. However in the 1990's when I had a 1299cc 65bhp Citroen GSA engine running through the "1015cc" Citroen Ami Super gearbox ; that was designed for 50bhp; it broke a planet wheel in the differential. Is this a problem with the R4 too? or do people slot the R5 gearbox in too/does that physically fit in the R4?
(5) The Fourwheel drive system.
I assumed that it may have been a system similar to the original Fiat Panda 4x4 system; whereby once 4WD is engaged it is locked centrally. So at least one rear wheel rotates with at last one front wheel.
However I saw a photograph showing two floor mounted levers. So does it have a rear diff lock? (like the contemporary Citroen Mehari 4x4?; or is it one lever to pop it in; and another to pop it out?
(6) Is there an extra low ratio gear on the 4WD gearbox? Or do they have a lower final drive ratio; or are the gear ratios "standard"?
Why the R4 for a trip? I probably don't need to mention this to any of you....
Whilst I have considerable experience on Citroens; I have never had a Renault ; so any experiences or particular problems that you can raise will be most useful; and I can think about.
Thanks for any information or advice in advance. I will dip into this site every once in a while; so apologies if I cant get back and thank you right away.
Cheers
Mike
(2) Engines
- Soft suspension to exploit off road traction
- Light weight to push car out alone (as I have done on 2CV's)
- Fuel economy
- Longitudonal engine (easier to work on; I have removed single handed with no lifting device engines/drivetrains from Citroen 2CV's; GS's)
Cheers
Mike
