Paul f6 spain
- Spain
Hello gents,
This evening I had a good run about in my F6, on the journey home I noticed the aftermarket temp gauge rising then the factory water temp light came on, i eased off and limped the car home, it ran at higher revs as if the choke was on, as i pulled into my steet and put it into reverse to park it made some weird and off pytting sounds from tge engine bay.
There was a trail of water down my street. I checked under the bonnet and the over flow bottle was nearly full and mercky. Then I had to stall the car to stop it. When I turned it off and removed the ignition keys the motor still ran !!!
After an hour or so I went back to have a look, i filled the overflow tank to it's correct level and started the car, it started on the button as it always does, revved it and it sounded fine. There's no signs of any mayonnaise on the cap or dipstick but naturally I'm thinking it could be the head gasket.
So gents, any help or guidance would be greatly appreciated.
Thermostat ?
Water pump ?
Head gasket ?
Thanks in advance.
Paul F6.
Thermostat ?
Water pump ?
Head gasket ?
Thanks in advance.
Paul F6.
