R4F6 No brake adjusters
  1. A spooky ghost
    A spooky ghost Enthusiast
    24
    USA
    On our 2370 F6, it has for wheel drum brakes, with no external adjusters pn the backing plates. How does one adjust the front drums? I think I'm missing a few pieces inside the wheel(for the auto adjust).
    No mechanism is there.....
  2. A spooky ghost
    24
    USA
    In a perfect world, how does the auto adjuster on the front drums work? Is it like the rear ones?
    When I bought this thing I asked the owner if it had disc's. He quickly said the discs are no good, and lock up. I wonder if this car has had a retro fit of front drums.....
  3. mojobaby
    mojobaby Enthusiast
    1,082
    Lot et Garonne France
  4. A spooky ghost
    24
    USA
  5. mr-reno-139
    mr-reno-139 AKA Paul Cunningham
    1,767
    lancing west sussex england
    Drum brakes on early dashboard model f6 van 1980 81 has got the redundant brake levers for front handbrake setup still fitted
  6. A spooky ghost
    24
    USA
    This is a 81, so with the older style dash. I'm gonna have to go over the manuals, on how to adjust them.
  7. A spooky ghost
    24
    USA
  8. angel Enthusiast
    1,723
    Athens,Greece
    It's early '81 or earlier still (external door hinges), so it's correct to be fitted with drum brakes front. They should be the larger 228mm diameter ones.
    In theory, and to some extent, they are self adjusting by the lever and ratchet under it on the first photo.
    In practice I found that they will often leave the shoes a bit farther away from the drum than they should be.
    The solution is to drill a 6mm hole on the drum face, roughly at a radius where the outer edge of the ratchet is. Note that on many drums the hole is already there (at least that's what is mentioned in the workshop manual).
    Now by rotaing the drum and putting the hole on the correct position, using a screwdriver that passes throuh the hole you have two options: either loosen the adjustment, by pivoting the ratchet clockwise (anti-clockwise for the opposite side), or bring the shoes closer to the drum, by trying to push the lever towards the hub center. If the adjustment is loose, you will hear the ratchet clicking as you push the lever. If it's OK, you will not be able to push it further in, or the drum may lock, in which case you pivot the ratchet and start over again.
    It's much simpler in practice than trying to describe it in words...
Advertisements
Clementine's
Renault 4 Garage
