R5 gearbox
Marlyn1234
Tonbridge
Hi all.
Can anyone help. I need a R5 mk1 5 speed gearbox. My Rf6 1397 has a poorly one. The round identity disc on the cover has - HA1 003.
I have searched breakers in England and Le bon coin (loads of gearboxes just not the right one) to no avail.
07730449373
Cheers
hi!
I would like help you.
Here in Spain it's simple found the gearbox.
But I will explain you what I know.
If your F6 has the original gearbox it's the most short box. The final speed is about 130 4500-5000rpm. It's a good box if you don't wanna go fast but with enough power.
The box of R5 GTL 5 speed has the same final speed than the ordinary R4 TL o GTL. The difference is just one more speed.
The box of R5 tx is 1000rpm-31,2kmh
The box of R5 ts is 1000rpm-27,4kmh
Both box R5 5speeds.
TX
25,2 km/h. a 1.000 r.p.m. en 4ª., 31,2 km/h. a 1.000 r.p.m. en 5ª.
max speed
km/h (en 4ª. a 6.005 r.p.m.) 151,26
km/h (en 5ª. a 4.825 r.p.m.) 150,63
TS
km/h a 1000 r.p.m en 4ª
velocidad máxima 150 km/h aprox
in the end if you want more final speed i advice you the gearbox of a ordinary R4. It's the most balance box.
Many thanks for the info.
I may have found a box in the UK, its a TX. If not I will contact you again.
Thanks again
We have discussed about 5 speed gearbox on R4 many times before here on forum.
Here is one among last topics on that subject.
http://www.renault4.co.uk/forum/threads/hot-or-not.8284/
and my post where are shown numbers (theoretical) what are possible benefits of that 5speed gearbox.
http://www.renault4.co.uk/forum/threads/hot-or-not.8284/#post-54986
Aldo it is more of "cosmetic" update on R4 I would very much like to put one HA1-01 in my R4 to experience it on the road!
Marlyn1234.......Hope you will find gearbox and make your F6 run again.
i think the positive benefits of a 5 speed gearbox it's have too a 1400 engine. or vitaminated.
In any case it's better have 5.
It's more cool say... Hey you have you seen me 5 speed gearbox in me R4??
That is just a joke
I've drove a r4 with a 1108 and 5 speeds and it moves very good.
I don't know if were a Tx or Ts box.
in the center.
120 km south from Madrid.
Center of castilla la mancha.
Martin
Just got back from a trip to Italy and seen your posting.
Sorry to hear it is not an easily solved problem.
Have contacted someone I know to see if he can come up with anything.
Best regards
Tom
The 03 box was Spanish only pretty useless for economical cruising so forget about that option
02 best box in my opinion
01 is same as 4 speed once you are cruising
Many thanks to Malcolm for your restoration tips on your R5 gearbox forum.
Your supplied box is now fitted and my F6 is fully repaired and running smoothly again.
