mojobaby
I've decided to start a new thread as I don't want to use Petak's post to solve my concerns and problems with my carburetor. He has enough problems of his own to solve
Because of the difficulties I've had over the past couple of weeks with irregular running and idling I decided to open the carb to check for cleanliness and any obvious problem.
The first thing that I noticed was that the surface of the top gasket was wet with fuel, so this could have been a place where air was being sucked in.
Here is a photo of the two halves when I first opened up. The bowl looked fairly clean, but the throat of the carb was dirty which I think is caused from oil fumes being sucked from the rocker cover
