What have we done this time (R4 F4)
Not in kitchen but on work desk in garage where my kingdom is. :)
Another adventure begins my friend !
I have just caught up with this news
What a great project - my girlfriend wants one for her floristry deliveries
You are completely right.....another crazy adventure on horizon.
Similar idea is crossing my mind. Find local pizza restaurant and do deliveries around town with yellow F4.
That would be fun!
Mean while i got few more pictures of the chassis
All crossmembers are in place and welded
Floor is next in line
But before floor inside of crosmembers need to be protected
If everything goes well sometime next week chassis should be finished and ready to be delivered.
Also have done some test zink plating in my bath
Here you can see left part of the tube frame which is zink plated and left side that is not
Here is same peace where lower part is zink plated and upper part was plated earlier and wire brushed
And here is same piece. Left side is freshly zink plated and right side is wire-brushed zink plated surface.
Surface quality could be better and for sure would be better if it was done by professionals.
But surface will be painted any way so i am only want to get some extra rust protection.
Still thinking send small bolts, nuts and spacers to professionals as they won't be painted
They are standard jack brackets but freshly made from metal plate.
Today got some more pictures
Anticorosion 2K epoxy primer is on the chassis.
After epoxy dried black paint is put on.
Now i need to talk to transportation when it will be in Zagreb where i will pick it up and bring back to Vodice.
I am ready
Yesterday picked up brand new chassis made by Andrej Mlinar from Slovenia.
It came to Zagreb in big truck and then i tie it down to my "construction" tight as ham ready to be smoked.
It is sitting in front of my house now.
Hopefully it will go to my garage friends on stands and wait for other parts to bolt on.
If that won't be possible then it will be stored for while until other parts are ready to be bolt on.
A lot of small (but still big jobs) are done. Very dull and boring but must be done.
First i put paint striper on different brackets around car and left for an hour
After that sandblasted in my small sandbox.
After which i get smoot and clean surface ready for galvanising
In my home made galvanising bath
After which i get nice and rust protected piece of metal
Next step is antirust primer
And 3 coats if black paint and 3 coats of varnish.
Hope all this will be anought to last for next 20 years :)
We are making progress slow and steady
Chassis striped down. Front torsion bars removed.
Rear axle is welded to chassis so i need to cut it off (still need to do that)
In the meantime i opened, serviced, cleaned and painted starter and alternator
Starter was in good consdition so nothing had to be done on it.
On the otherhand alternator needed some attention
Rotating contacs were worn out
And atator was really dirty and greasy
New rotating rings instaled
Both put a side waiting to be mounted on engine
Gearbox cleand
Engine striped down part by part , cleaned, changed gaskets, semerings and everithing else i have found that need to be changed
Valve cover removed, some dents puled out, and painted, valve clearance checked, new gasket put
Some sludge found out inside valve cover.
Chain cover removed
And it looks like chain is streched a lot.
I could not managed to find how much strech of the chain is aloved. I manage to move it 1,2cm inside on this picture. To me it seems to much.
But in some discussion with Mlinar brothers find out that new reproduction chains are not so good and will strech in less than year. They say (Mlinar brothers) it is better to keep original chain if it is possible
I have already ordered new chain and tensioner
Still did not put it on (have to find time to do that)
Chain cover sandblasted
andpainted, ready to be mounted.
New gasket is waiting.
That is it for now.
New adventures are coming soon.
It may just be the photo, but the crankshaft gear looks well worn. In any case, I would try to replace both gears, too.
Tx for comment!
Did not check gears!
How can i tell if gears are so worn that can not be usable anymore?
It is not easy to find new one.
What is you oppinion about quality of replacement chain?
Teeth will be sharp at their edges (new ones have a nice radius). Look closely at the tooth profile and if you notice more pronounced wear pattern at the drive side - the tooth profile will look asymmetric - it's time to change them.
In theory, slightly worn gears will wear a new chain rapidly. In practice it's as you say: gears are hard to find new. They however used to be available as kits (gears/chain) from aftermarket suppliers in the past.
INA is a reputable company regarding modern car timing kits, but if you are still in doubt regarding its quality, you can go another way: Last time I changed a timing chain on an R4, I found a good quality chain (Sedis) from a 70's Peugeot, cut it to the required length minus one link and joined it with a join link. If you fit the clip the right way round, there will be no problem at all.
TX Angel!
Will check teeth and then decide what to do.
Chain that is on engine now is definitely to stretched and must be changed. So there is no much choice i can do.
New chain goes in as i already have it.
Sprockets must locate first
I have to say that 150.000 kms ago I changed the original timing chain and sprockets (and tensioner of course), that was working fine since 220.000 kms before, but since I was taking off the engine to do a major rehauling the mechanic suggested to change them as well. The new one failed me, as I said, after 150.000 kms because (as we saw once the cover was open) the lower sprocket, the smaller one, was almost round shaped from wearing. I don't remember which brand I fitted, but they came from a specialist r4 parts seller that has all my trust for what matters honesty and care in looking after spares. Now I fitted a NOS kit that I bought a few years ago in a classic car fair, let's hope it will last at least another 150.000 kms...
PS: fortunately no arm was done to the engine, the chian slipped but one step and valves didn't hurt anything.
I would be happy if new chain work flawlessly for next 150tkm.
Will.post few pictures of small and big sprocket.
Would like to hear your oppinion shoud sprockets be changed or not.
Big sprocket
Small sprocket
Am i missing something?
I can not see any big wearness on sprockets.
Thank you in advance!
  • Like
Reactions: DAA
