door surrounds
Malachy
Uk
#1
Hi all
I have a 1969 4 with really badly rusted door window frames. Is there a simple way of removing the frame and replacing it with plastic ones, front and rear.
malcolm
& Clementine the Cat
Staff member
Bedford UK
#2
The plastic ones fit. Trouble is removing the old ones as the screws will be rusted. If you remove the seal you will see the screw locations and can grind them out with an angle grinder without messing up the exterior paint. A bit of paint on the bare metal anjd plastic window frames can be popped in.
Malachy
Uk
#3
Many thanks Malcolm.
Do I need to glue in the plastic ones or try to preserve the screw holes?
Do I assemble with the glass in place?
malcolm
Staff member
Bedford UK
#4
The plastic frames go in with the glass in place and are seured to the frame with little metal clips.
