jcarruthers2
Hi
I'm trying to help somebody out with a problem with the indicators on an R4gtl. They are not working, front and rear. The hazard function is also not working. You can hear the flasher unit operating when you operate the indicators but no flashing lights. Fuse is ok, there power at the light units, good earth. The indicator warning light on the dash stays on with the ignition on. The indicator warning light remains dimly lit even with the indicators switched off which it should not do.
Any pearls of wisdom as to what the cause might be would be appreciated.
