Renault Rear window insert
RichardIRL
Dublin
Does anybody know the Renault part code of the rear insert (black or silver) for the Renault 4's rear window?
or even a good way of describing it to a Renault garage?
I think the item you describe is the "bead" for the window rubber. If you order the window rubber it should come complete with this. I'm not sure of the part number or availability.
The rubber and the beading are listed as two seperate items. I don't think the chrome beading is available now so you have to go for the black one. It used to be available from Renault - you'll need to measure the length though before ordering.
I found the silver ones available from windclassics.nl listed under
Sierstrip voor in de ruitrubbers (achterruit)
Artikelnummer: 1002
but I wanted the black ones which is cool thanks a million
