AdamWilkes
- Poole
There are 2 different 160 mm renault clutches 1 is designed for different rotation engines
Without knowing part numbers you may have trouble selling this as very few 1108 r4 had small clutch mainly used in early 1970s R5 and R6 both 956 and 1108 engines models
The 845 engine uses 160 mm but rotates other way round
The clutch cover plate is the difference
Hi - thanks for the input - I had no idea! I have now inserted a photo in case this helps.There are 2 different 160 mm renault clutches 1 is designed for different rotation engines
