lagunanewbie
I recently limped home in my laguna (felt like fuel starvation). I had the feeling that I may have run out of fuel.
I put a 5 Lt can of diesel in and tried to start it with no luck. Referring to the Haynes manual, I proceeded to prime the system but could not get fuel to the bleed valve.
I cobbled together a vacuum system and successfully got fuel to the pump, still wouldn't start.
I figured it must be the stop solenoid that was causing the trouble, so following the Haynes manual, decided to remove the solenoid. I spent a couple of hours trying to remove the part, totally destroying it in the process, only to find that it wasn't the solenoid after all.
I haven't got a clue what part I managed to take off, or for that matter where the stop solenoid could be.
Grateful for any help.
