A.C.WILLIAMS
Hello, A.C.Williams Ltd of Ancaster have a HUGE stock of old parts including such things as New R4 bumpers (many of them) and lots of other bits.
If interested call Chris on 01400 230049 or e-mail ancaster@ntlworld.com for a list.
I don't want to be sorting through for a £1 gasket so would rather sell small items in bulk if poss.
Thanks, Chris
Examples...
PART NUMBER DESCRIPTION MODEL BIN QUANTITY
R08 54 720 000 ROTOR ARM R456 4 40508A 5
R08 54 725 600 CONTACT SET 4 40503G 28
R08 54 913 300 ROTOR ARM 4 40903L 8
R08 55 238 500 AIR FILTER 4 50102B 14
R08 57 113 600 CONTACT SET 4 40402G 3
R09 96 064 400 KIT BALL JOINT 4 40809C 11
R77 00 501 752 DRIVE PLATE 4 43101D 3
R77 00 504 343 GEAR SPEEDO R12 4 40213K 3
R77 00 520 857 CABLE 4 50306G 3
R77 00 522 372 GASKET MANIFOLD 4 40220K 5
R77 00 571 741 CABLE H/BRAKE R4 4 50306G 21
R77 00 582 780 HINGE 4 45237H 4
R77 00 586 110 BELT 600 MM 4 43103H 70
R77 00 644 463 BELT 675 MM 4 45603K 2
R77 00 646 172 BRACKET DASH R12 4 40235E 1
R77 00 650 696 WASHER 4 40305L 2
R77 00 650 697 PLUG 4 4 45221G 39
R77 00 685 130 CABLE H/BRAKE R4 4 45603M 3
R77 00 685 131 CABLE BRAKE R4 4 45602M 2
R77 00 691 367 SEAL W/SCRN R4 4 40418B 3
R77 01 003 813 CONTACT SET 4 40403K 36
R77 01 006 838 BRUSH CARRIER 4 45223A 3
R77 01 007 215 SWITCH R4 4 45402C 2
R77 01 017 392 BEARING CLUTCH R4 4 40908C 10
R77 01 024 136 LENS S/LAMP R4V 4 40804L 2
R77 01 027 802 IGNITION LOCK R4 4 40914E 1
R77 01 200 691 KIT M.CYLINDER 4 45041M 3
R77 01 201 205 B/SHOE AXLE SETR4 4 50504C 2
R77 01 201 214 B/SHOE AXLE SET 4 50403C 21
R77 01 202 334 B/SHOE AXLE SET 4 50201B 9
R77 01 348 035 CABLE HANDBRAKE 4 4 50306G 3
R77 01 348 210 FUEL PUMP R4 4 45302L 4
R77 01 348 349 REGULATOR R4/5/6 4 44003A 5
R77 01 348 454 BUSH LWR S/ARM4/6 4 40320A 8
R77 01 349 005 LENS S/FL R4 4 43304D 3
R77 01 349 013 BASE R4 4 43303D 6
R77 01 349 014 R4 BASE 4 43304D 6
R77 01 406 782 WIPER BLADE 300MM 4 506A00 45
R77 01 450 588 ARM STG R4 4 40501K 1
R77 01 451 904 BALL JOINT 4 45502F 1
R77 01 461 353 ALT CONV KIT 4 45502B 1
R77 01 463 080 KIT DR/LOCK RR 4V 4 40807B 1
R77 03 004 011 BOLT 4 506HC2 128
R77 03 074 161 PLUG 4 45136C 100
R77 04 000 278 JOINT R4/6 4 41313B 2
R77 04 001 903 HINGE LHF PILLAR4 4 507LF1 2
R77 05 035 113 PIN HINGE 4 45116H 11
Thanks, Chris
Examples...
