Hi damir,
Carburettors do not go out of adjustment, so should not need adjusting unless they have been fiddled with in the past. Adjusting the carburettor should be your last resort.
The first step would be to service the engine, ensuring that the distributor parts are in good condition. An engine that has not been serviced regularly will run badly and have excessive fuel consumption.
Next, check that all of the pipes and hoses are still connected to the carburettor and check there are no holes in the hoses. You might need to unscrew the air filter cover and the air filter base to view the carburettor.
Then remove the air filter and look at the top of the carburettor. Make sure the flap at the top (the choke valve) is fully open when the choke is pushed fully in. Otherwise the choke cable will need adjusting.
Finally, if none of these things have helped, and you suspect someone has messed around with the carburettor in the past then you might want to check the mixture setting. There is a screw with a spring around it on the body of the carburettor facing the inner wing. Screw this fully in, then screw it out by 1.5 turns. That should give about the right mixture setting.
Let us know how you get on.
