needing to sort this out on my 67 TL.....it had previously been messed with....the Haynes circuit shows a flasher unit with 3 connections (supply, conn to switch common, and conn to tell-tale facia lamp)
when i bought the car, it had a Citroen flasher unit with supply, conn to swich common and earth (the tell-tale was wired across left and right feeds)
question is, firstly, has anyone increased the power of the lamps from 6V/15W to 6V/21W (more readily available), and has anyone sourced a flasher unit of the type similar to the original but with a higher wattage capacity....Adrian
