David Norville
- Spain
I know a lot has been written on this subject but I just have a couple of questions before I try and source the holy trail of performance parts. I understand you need the manifolds to accept the Zenith 32 carb but are the manifolds for the Solex 32 interchangeable? Here in Spain both Carbs seem readily available new for reasonable money 80 Euros ish, which manufacturer is preferable ?. Also I read the rocker cover needs to be sourced from an 1108 Renault 5 mark 1 for routing the accelerator cable but on my 1983 Renault 4 tl the cable already goes through a bracket on the rocker cover, so will it suffice or is the bracket in the wrong location on my 4tl ? Thanks, there seem to be a reasonable number of Mark 1's down here in Andalusia so I am optimistic I can get second hand bits .
