How to remove the rear side window?
Pavel
Hi R4 friends,
before I destroy whatever, can you advise, how to remove the rear side windows, without damage the glass or the rubber seal? :confused:
Many thanks and nice greetings from Prague
Pavel :hug:
Hi,
its not too bad to do.
Step 1:
Loosen the seal: Using your fingers or carefully with a screw driver lift the seal up on the inside of the car to make sure its free and loose.
Step 2:
Carefully start to prise the seal down while pressing the window out. I seem to think it was easiest to start at the top.
Step 3:
Catch the window before it falls out on the floor and breaks !
Anyone else got a better description ?
Easy!
Pull the inside seal down with a screwdriver. Insert the shank of a pop rivet at 90 degrees in between the rubber and the frame. Repeat every 1 1/2". Put the palm of one hand on the glass and gently tap the glass inside with the other hand. The glass and rubber will soon be released.
Should take 5 minutes if you're slow!
I've done for the rear doors windows, to swap the fixed ones with the opening ones from a scrapyard donor...
