Steve Hennessey
Moderator
1 x pair of genuine new Renault inner and outer suspension bushes for the R4 GTL. If you are overhauling your rear suspension then you need these parts. I think they are only suitable for cast rear suspension arms as opposed to the pressed steel variety (but happy to be corrected).
The inner brackets come with the bush and if you have any spline problems then a new or good torsion bar will slot in nicely. The outer bushes would need to be mig welded into your original brackets.
Note: There is some surface rust on the brackets!
£25 the lot plus postage (£8 Std parcels)
