Renault 5 driveshaft seal help
bunglebus
Hi all, I'm having problems with the O/S driveshaft seal on my '93 R5 1.4 Campus - oil leaks from the seal where the driveshaft goes into the gearbox, I have fitted a new genuine oil seal but it still leaks, there's an o-ring which I'm not sure about, does it just slide on over the splines before the driveshaft's fitted or is it meant to tuck inside the oil seal? The Haynes diagram isn't clear and it isn't mentioned in the text :confused:
I had the same problem with my R4 van.
The solution for my problem was shortening the spring in the seal by about 4/5 mil.
Been running for more than a week with no oil spill.
Similar problem on our 1968 R4. Not solved yet....nettle to be grasped...etc etc
toodlepip!
David B.
(dry warm and sunny in the Pyrenees)
