Tripyrenees
- Luscan, France
Symptons - started to run a little lumpy but with choke slightly out it was OK. Starting prgessivley got harder, but thought it was due to becoming colder here. Then finally it did not start at all, after a short run (1km) to the supermarket. Towed it home.
What I have done so far;
1. Changed condenser - no change
2. Tried a second coil - no chamge
3. Cleaned and set gaps on all spark plugs
4. New set of points with gap set - no change
5. Check spark at coil, before spark plug and at spark plug - all good but no change
6. Removed carb and took thelid off, cleaned all jets with compressed air.
7. Checked feul squirt when pedal pressed- all good but no change.
What is next to check. This problem came on progressivley and now nothing. It does not even try to fire. A little bit stumped here (distributor and hence, the timing, has not been touched and is all tight)
Thanks in advance (this is my son's daily driver)
). A lot of sludge in the bottom of the block which explains the overheating issue in busy traffic. I will try and dissolve this out when the engine is back running asI don't won't to get the crud into the oil chambers.
