Wanted Renault 4GTL
4F6 User
I am looking for a Renault 4GTL or similar to buy. It must be right hand drive and have an MOT (although I may consider a project as long as it only requires minimal work). Any assistance with my search will be gratefully received.
Renault 4 GLT Wanted
How about this one?
What is you budget?
It was first registered in 1985 and stayed in the same Herefordshire family much of this time, all be in being swapped around between various members. I’ve had it since the mid 1990’s, although it spent a good few years of this being restored, before fully returning to the road last year.
A few pre-completion of restoration pictures can be found at-
http://www.renault4.co.uk/images/chris-collins-fr.jpg (click on pictures if in reduced scale)
Any prospective purchaser will find the following:
Mechanical/Exterior
Engine reconditioned at only 68k miles to enable conversion to ordinary unleaded fuel, included full replacement bearings, cylinder linings, gaskets and hardened valve seatings, etc.
Complete body and chassis strip down, with additional rust-proofing and sub chassis component renewal, including new boot floor/internal rear wheel arches (Zintec coated).
All body panels replaced as new, including Zintec coating prior to painting. (inc: all wings, engine bay panels, bonnet, tailgate, rear side window panels, front A-panels, sills, bumper mounting panels, etc)
All suspension and associated mechanical parts replaced with new and enamel powder coated prior to fitting
New steering rack
New engine mountings
All brake components, discs, callipers, drums, manifold/pipes, etc, replaced with new.
New clutch and drive shafts
New water pump, fuel pump, fuel lines.
All new water hoses and radiator flush
New ignition coil, distributor, leads, etc.
Fitted with Luminition electronic ignition system
New Solex carburettor
New starter motor
Reconditioned alternator
Complete new exhaust system to engine manifold
Enamel powder coated engine bay components including all support struts, air filter cover, engine rocker cover, etc.
New headlamps and all new other light fittings, including additional high level brake light.
New bumper and associated components, all enamel powder coated prior to fitting
New front grill, including headlamp fitting housing
Enamel powder coated wheels matched to original colour
Tow bar complete with wired electrics and indicator buzzer
New door rubbing strips
New side mirrors (left and right)
Complete new window and door seals
Etc, etc…..
Interior/additional features
Immaculate original brown check upholstery, including genuine colour matched Renault 4 head-rests
Additional sound proofing throughout, including behind body panels/bulkhead and roof lining.
New carpets throughout
3 point rear seatbelts
Blaupunkt 4 speaker Radio/CD player
Parrot CK3000 Bluetooth hands free phone kit
Dashboard digital clock
Twin interior lights
Toad Category 1 immobiliser/alarm system
12v accessory outlet
Etc, etc….
Renault 4 Wanted
Your Renault 4 looks very clean and you've clearly spent a great deal of time on the car. Whilst I am very interested I suspect however that it is outside of my price range.
How much are you wanting for the car?
If that frankly lovely example is too expensive my Father has a red GTL for sale. Its got 9 months MOT on it and is in presentable condition. Not perfect but it's being used daily at the moment so it wouldn't be. He'd probably also throw in some useful bits if you wanted them
Yes I'm very interested in your father's Renault 4. I currently use a Renault 4 van which is in a similar condition and I find them useful everyday transport.
Does your father have an idea of what price he is looking for? Where is the vehicle and would it be possible to come and see it? I note that you say your father has some useful parts which I am also interested in.
If you want to discuss offline then please call me on 07814 147324.
I just wondered if your red GTL is still for sale as I hadn't heard anything from you. Let me know as I am still interested if it is?
