davebandit
Sometimes it starts.
Sometimes not. When it doesn't, if I persist for several minutes cranking the engine eventually it will start.
Not related to damp/fuel load/spark.
Renault said I needed a new Key with a new code, Cheers coz that also didn't work.
I'm worried my ECU is faulty, I've heard that the crank sensor may be giving duff information to the ECU even though it appears to be reading correct and that re-seating the crank sensor may reset ECU value and hopefully start the car. Or perhaps the ECU just isn't interpreting
However it ALWAYS starts if the engine has been running recently, if left for a while it might or might not start.
I've had new air inlet valve aswell. That's just screwed my idling up, now it's eratic!
Has anyone experienced this or can offer any help? if you can you can have my car for free when i'm finished with it!
