malcolm
& Clementine the Cat
- Bedford UK
Does anyone know anything about distributor types for early engines? I've bought a 123 distributor (above in photo) but the body is different from the distributor that came out of the engine (below). It'll fit if I remove the bush and seems to be designed for a clamp down fastening rather than a pinch bolt fastening. Wondering if there is another mounting arrangement with a shorter bush and different clamp used on some other engine. Or is I have just bought the wrong distributor. Franzose and 123 say it should fit the 680 engine but I can't see how.
Looks like I should have bought a Dauphine version advertised for the 670 engine. Would any parts from a later engine help it to fit? I could maybe cut the bush down and improvise a mounting, or try to machine the body to the right shape.
