72 TL live feed
Andy McGhee
Cheltenham
Hi All
Where's the best place to attach the (fused) live lead of an accessory socket on an early (72) TL?
On the A position of the ignition switch. Take a look at its connector under the steering wheel, you will notice a four terminal connector with four wires coming from the switch but only three on the wiring loom side. You simply fit your wire with a male Lucar connector in the empty position of the connector and you are done.
