Battery cut off switch
edwin
Lichfield
Gentlemen. I am thinking of installing a battery cut off switch to my R4. I will position it on the bulkhead to the right of the engine (from drivers position). I will need to extend the battery lead from the battery to the switch, and then use the existing loom to connect from the car to the 2nd pole on the battery cut off switch. What size (diameter) of cable do I need for the wire from the battery to the cut off switch. I think its about 110cms long. The engine is the 845cc, 4 speed, 1985 yr of construction.
Thanks for your help. Edwin
You can get isolators that go directly onto the battery terminals, had one on my old fairway taxi years ago
