malcolm
& Clementine the Cat
- Bedford UK
For my Gordini I want to fit a remote servo and a remote brake reservoir. Finding the parts is driving me crazy.
The master cylinder is the early single circuit type, and as I only need one feed to the remote servo I need to blank off the other two outlets. They are 3/8 UNF to take female brake pipes (the wrong type for blanking with bleed nipples). Any ideas for blanking would be much appreciated as I haven't been able to source blanking plugs. I'm thinking of having something machined up.
The remote reservoir is needed because the carb gets in the way of filling. The thread appears to be M16 * 1.5mm, and a rough plan was to find a hose tail to convert to 6mm ID pipe and then back again. I've not been able to find these either (I can use an adapter to BSP thread, or just fill with a funnel and hose so it's not a big issue).
Any ideas for places to look for any of this would be most appreciated. I've been trying to figure this out for months and it's really holding up the project. I even wasted a fortune on a different master cylinder aimed at kit cars, but that can't be made to fit properly and has me in a bad mood.
