Greetings,
I'm new to the list and looking for help with a wheelhorse tractor which uses an R4 Renault engine. Recently a loose screw in the distributor came loose and seized the distributor which results in the snapping off one side of the receiving cam shaft gear. The distributor shaft is fine but the receiving gear is broken. I removed the broken piece and took a couple photos.
I think I have to remove the bushing to get to the shaft and it seems it requires a special tool that threads into the bushing.
Any help would be greatly appreciated. I'm very much stuck.
Thank You.
Bill
Thank You.
Bill
