Carburettor water pipes
Simon Knight
Sawbridgeworth
Hi all, does anyone have or know where i can get the water pipes that go to and from a 32if carb please?
Cheers Simon.
I used hydrolic hose. It can stand heat and oil. You just need to find a local farmers Or mechanic shop that have it on a big roll.
Thanks for the tip, it seems to be available online. Just out of interest does anyone have the part no`s for the original pipes?
Cheers Simon.
Hi Simon
This page might help (although the same parts might have other numbers too):20200919_175556.jpg
I've got a set (I had to get them from Spain) that I'd like to hang on to:
If these are the bits you need (plus the bleeder valve), I've found these:
https://piezasautosclasicos.com/manguito-entre-bomba-y-purga-renault-5-y-7
https://piezasautosclasicos.com/manguito-entre-colector-y-purga-renault-5-y-7
https://piezasautosclasicos.com/pur...-renault-5-super-5-7-9-11-12-14-18-21-express
https://piezasautosclasicos.com/manguito-carburador-a-bomba-de-agua-renault-5-6-y-7
Is it a replacement job, or have the pipes been removed? If the latter, you may need the small metal pipes that screw into the water pump.
You could ask for some pipes to a LPG systems installer, the regasser uses the coolant to heat up, so they have some pipes to link it to the original cooling system.
Hi Andy, thanks for the reply and the links, those are the bits i need, i`ll try and order some later. I am replacing existing hoses. One of them split just above the jubilee clip, i was able to cut it off at that point and reattach it but it made me think i should do some preventative maintenance.
HI Leonardo, Thanks for the suggestion.
Cheers Simon.
