Early 1970s Renault 4 engine
SJC400
Fairford, Gloucestershire
This is a genuine, original early 1970s engine (oil filter under a plate on the side of the engine block). This is a good 845cc engine that I have removed the head from, to inspect the internal condition. All is good and the engine was running ok when removed, though a compression was slightly low on a few cylinders, so time for a decoke and light overhaul. The car has long gone though the documents still exist.the cylinder head has been overhauled and the valves ground back in, this part is ready to use. The block and pistons, though probably useable as they are, I would advise new piston rings and lower end inspection & clean.
It comes with the choice of the original dynamo, or an up-grade of an alternator. Other ancillaries are still attached and are included. Call me or email to chat further. Looking for £150.
I also have a set of liners and pistons, reusable for another engine rebuild, available separately. Everything here is for 845cc Engines.
46C86958-954B-447F-B7D2-2565F68B368D.jpeg54F6FE40-CE5E-4232-91BB-04D3E759239C.jpegF9CE6F02-D612-4D73-A3DD-F15221383A2E.jpeg6105BAE4-4D4F-4FB8-BE97-00ADEA81E1F6.jpegC0D95F9B-FC23-48AE-A2BE-68B3A7D4207A.jpeg
