I had issue with my brakes whereby there was no braking force, front nor rear when pressing the pedal.
Looking at the state of the master cylinder I decided to replace - 3 outlet type with pull off/push on single reservoir with two outlets.
I have also replaced all the front rigid brake lines, flexis, discs, pads and caliper seals.
System fully bled and when pressurised with easibleed kit there are no leaks from anywhere.
However, when pressing brake pedal it just goes to the floor.
My question is whether there should be anything between the "pushrod" attached to the pedal and where it seats in the end of the master cylinder. That is the only thing that I can think of that may be causing my problem.
B
B
