Nigelblandin
- Sudbury
Is there a correct thickness for the small spacer between the outer wheel bearing and the front hub? Just rebuilt them and when you tighten up the hub/ shaft nut it pulls tight against the back face of the caliper…
Worked fine before with the old bearings, which weren’t too bad. The new ones are dimensionally identical.
Big spacers are in place, everything seems fine..
Oohh… Did I press the bearings on too hard? If they are lightly ( but snugly) in does the end nut pull them up with the 130 Nm torque applied?
Does the spliced section come up flush with the inner bearing face?
