Genuine part numbers
Matthew MacMunn
Cornwall
For a 1989 956cc 4tl does anyone know the genuine part numbers for:
cooling radiator
Water pump
Rocker cover gasket
Heater matrix hoses in/out
Radiator: 7701348798
Water pump: 7701457671 - QCP957 is the Quinton Hazell equivalent: https://www.ebay.co.uk/itm/313681081415?hash=item4908d97447:g:xmoAAOSwnAZhSIGb
( or 7701463014 if you have the type of pump with extra connections - like these: https://spareto.com/oe/7701463014)
Rocker cover gasket: 7700723967 e.g. https://www.ebay.co.uk/itm/33420865...481876&hash=item4dd0635569:g:3RAAAOSwil1hhjGp
Probably cheaper to get a head set on eBay.
For the heater hoses: You can get a kit of radiator/heater hoses here (the lower radiator hose will be for LHD cars only - I'm guessing yours is LHD): https://vehicules-anciens.fr/en/shop/hose-kit-4l-cleon-engine-va19205-k824
More info here:
If you're passing through Cheltenham, I can probably help with all the parts except the heater hoses.
