just got it all ready for the mot but need to sort out the rough running
it has a bit of a misfire,im getting some plugs tomorrow,but the main problem is it wont rev properly unless you pull the choke out
with the choke in it hesitates as the push the throttle then on full throttle wont rev too high,sounds like 3000rpm or so
ive cleaned the points and checked the distributor weights are free and the vacuum advance is working , did move the distributor each way a fraction and put it back where it was as ive no timing light here today.The cap and rotor arm are ok
im guessing a partially blocked jet in the carb?
tried squirting the carb cleaner in it no joy
i did have it apart 6 mths ago to check the float and clean the fuel chamber out but not took it apart today
any ideas?
thanks
matt
any ideas?
thanks
matt
