Hello again, What should I make of this? My R4 has white smoke coming out of the exhaust.
I first thought it would go away as the car has been stored outside for about a year without being started, and the smoke was being caused by moisture in the exhaust and the engine. But I've had the car running for about an hour and it's still there! The strange thing is it doesn't over heat and only uses a tiny amount of water (expansion bottle dropped 7mm from max level after 30 min of use).
I ran the car for half an hour yesterday afternoon and left it overnight. In the morning I undid the expansion bottle cap and there was no hiss. However there was a milky sludge on the oil filler cap. Oil on the dipstick is ok though and there is no oil in the coolant.
See the pics of the offending article: http://s735.photobucket.com/albums/ww351/XKss21/Head Gasket/
I took the plugs out and did a compression test all cylinders quickly got to 150 psi (10.34 bar). Plugs were a bit sooty but not oily.
So is this defiantly the head gasket/ cracked head or could it be caused by something else??
The engine has done 85 thousand miles so I'm not sure if it's worth fixing the head gasket (It does have unleaded valve seats though.). My Haynes manual says I need some special socket to remove the head and that the wetliners can be troublesome. Any one with a spare engine for sale??
Although the car looks scrappy, the chassis is in really good order so it's certainly worth spending money on. I just want to get this car finally finished!
Any advice would be greatly appreciated. I've learnt a lot from this forum
Tim
Tim
