Hi ya,
a technical question for you more mechcanically- minded. My ignition coil was cracked, so I bought an original part from Renault-not all badly price.Anyway, the new coil has a terminal for the earth ring-tag and a self tapping screw, but the red wire connection hasn't got one-just two metal points to accommodate those sliding clips (?) What should i do since my red wire has the ring -tag ? Am i supposed to strip the ring-tag off and put two clips on the wire to slide onto the two metal prongs ? (by the way is it possible to remove the spark plugs with disturbing any part of the engine ?) Cheers for any guidance
