Inner rear suspension bushes
iMacThere4iAm
Tom Long
Morecambe
I can't seem to locate a part number for these bushes - does anyone know it?
Are the inner bushes the ones where the inside cylinder protrudes from the outside cylinder, or the one where they are flush?
I have the renault parts manual for R4 but what do you mean by "inner suspension bushes" ? also you had better quote model and year in case there's a difference ??
I think I've partly worked it out from the pictures on La 4l de Sylvie. It's the one that's being cut out in the first section, Silentbloc de palier intérieur. Definitely the right hand bushing in the image below. If you can find the part number that would be great :)
It's for a 1991 GTL.
Another question: Are these cast-iron and sheet-metal mountings interchangeable?
I fear they are not interchangeable as the sheet metal ones are the earlier ones for the adjusting cams (I think)
I think I have found it part no. is 77 00 627 830 looks like it's the same from 1983-1993 hope that's right no.
Thanks Montenegro, but that seems to be for the entire support including the bushing.
I've narrowed it down to four options, but I just can't work out which is which!
626057N
Diameter 27.5mm x 45mm, Length 65mm x 32mm.
83033
Diameter 27mm x 45mm, Length 65mm x 27mm.
531796N
??? 27.5mm x 59mm, ??? 55mm x 37mm.
83035
??? 27.5mm x 55mm, ??? 42mm x 26.5mm.
had another look, the ext bush is 77 04 000 999 int must be misnumbered as it shows it as the no. I gave you before ! OR both bushes on 1 number ?
