Leonardo.IT
- Tuscany (Italy)
Hello everyone!
I have a problem on my R4, a 1986 956cc.
When the engine is on and without choke it doesn't turn smoothly and usually turn itself off, even if it's warm.
The same problem comes when I drive with little throttle, even at "high" speeds.
First I changed all the electrical components, from the coil to the spark plugs.
Then I tried to change the carburettor with a refurbished one.
I also tried to change the head gasket, because I had a problem with the radiator switch and I thought that it could have been a cause.
The car when you hit the gas runs very well, and can even reach 140 km/h on the speedometer!
Anybody has experienced something similar before?
Any advice?
Thank you!
Any advice?
Thank you!
