misfire any ideas ?
montenegro
help, my 82, gtl has started misfiring badly, explosions and lack of power, only just got back home. so far have changed the distributor, coil, condensor ht leads and cleaned out the carb. I AM STUMPED. any suggestions please ??
Could be timing. Maybe the distributor has become loose and has rotated.
Check if its loose.
Try compression test maybe a valve problem have had pushrod come adrift with loose valve clearance adjusting screw
if the exhaust is not opening compression will show as good on testing but backfire through carb on running
Happened to me recently, intermittent misfire, changed everything incl carb, dist, coil, condenser, turned out to be ht lead arcing out ..... might be an idea to run engine in a dark place and check for arcing.
