New Brake-linings, (set of 4)
  • Thread starter Thread starter Jimincrewe
  • Start date Start date
J
Jimincrewe
Guest
These will cost you nowt, just petrol ! Collect only. You will need to do the detective work to see if they fit your car. The information on the boxes sent to me off ebay maybe incorrect, so I've done a piccie. Both were supplied to me as rear Bendix linings for an '86 GTL, which they ain't. That is preservative not rust you can see. Measurements are approx. for drum.
1 set - 180mm RBS168 on box, 1AFJ on lining. (poss. pre '67 front)
1 set - 200mm 5064/a1885 on box, H225w M19J on lining. (poss. '67-on front)
I'm guessing the above 'cos I've only memory to go by.
I've just been looking in the Quinton Hazell catalogues and the 180mm set look as if they are Bendix rear shoes for all R4's with 180mm drums. The 200mm set do not look anything like R4 front shoes. Hope this helps.
