I had exactly the same issue - a new fuel sender sorted it.I have an 86 GTL and have no fuel to carb . Not checked pump yet , but only 4 years old , as are fuel lines. Is there a filter in pump and on pick up in tank which maybe blocked.
Thanks I will try with airlinethere is,a gauze filter that is in the tank
needs sender out and tank removal for acess
try pulling pipe off pump and blowing down towards tank may clear it enough for diagnosis
Think you right, blew down pipe, heard fuel bubbles in tank, checked pump working, it was, eventually she started. Probably have tank and clean gauze, before I get caught out again.I had exactly the same issue - a new fuel sender sorted it.
