Parts Wanted and Parts available to swap or sell
ryanrenault4gtl
Llanelli
Merry Christmas everyone, hope you've all had a great holiday.
Looking for the following parts to get my daily driver back up and running -
* Rear Bearings - 2
* Front Bearings - 2
* 1 Front ball joint upper
* Oil filter and air filter
Does anyone happen to know where I could find these parts? I've been having a look and can't find any, a bit lost and would really appreciate some advice.
Parts available -
*Chrome bumpers (good condition) front and back - I prefer not to send these as it would be a little expensive, so local pickup or we could meet halfway if it isn't too bad.
Kind regards
Ryan
Hi Ryan
Your car's a late GTL, isn't it?
Rear bearings:
Front bearings:
Upper balljoint:
I can help with new oil filters (Champion).
Could you measure your air filter (Height/internal diameter/external diameter)?
Hi Ryan
Rear bearings:
Front bearings:
Upper balljoint:
Thank you so much!
After searching for a while, I've tried autoparts Pro and managed to get the lot in one order. What's a relief is that what you've shown me matches to what I've bought! Thank you so much for your help.
It's a TL 1989 from Spain, but I believe its the 34hp version not the 44, but for these parts fortunately they're the same.
Just spent 96,79 on the following with autopartspro
*Air filter by Mahle - height 78 diameter inner 151 outer 205 prod no. LX140
* 2 quinton Hazell ball joint upper front axle left and right.
*Skf wheel bearing kit rear
*oil filter
*4 plugs
*quinton hazell bearing kit front
Hope they won't take long to deliver as it's the daily driver , will let you know if they're all good! Thanks so much again.
Regards,
Ryan
