malcolm
& Clementine the Cat
- Bedford UK
Hi all, I received an e-mail about a Renault 5 starter motor issue. I'm baffled. Anyone else have any ideas?
I can't see how a starter would make funny noises as the engine is switched off, while presumably not doing so when the engine is running.
:clementi:
I have a 1996 Renault 5 Campus Prima with the same/similar starter motor. My problem is not on starting, but when I switch the engine off. There is a noise comes from the starter similar to that if you keep the ignition key turned too long when starting the car.
I removed the starter yesterday tested and greased etc, but no difference when I replaced it?
I would be grateful if you had any ideas?
:clementi:
