Replacement headlights?
Try https://www.franzose.de/en/Renault/Alle/Scheinwerfer-Zubehoer-Halterungen/ANR85072/ - this is a Der Franzose part number 85072; looks like about the best available, but will be left-hand drive, so look up Malcolm's article on converting headlamps to right-hand drive. These lamps are at least E-marked which suggests better quality than some others available (like from India). No guarantees that the mountings may fit straight-off - they may need some tweaks (possibly depends on the age of the car).
I THINK these are the ones I am using now, they are the third new pair I have tried - the others had such a rubbish beam 'pattern' that they were dangerous to use. Not cheap, but I wasted the same money on lights I couldn't use, so worth spending to avoid wasting! My beam pattern is a bit 'pac-man' in shape but is safe and MOT-compliant.
