I have a really sound bodyshell from an originally French registered R4. I bought it because I needed an engine in a hurry as ours blew up and this car became available with a good one. Arguably, it was too good to break, but I did, and need to shift the shell. there is a hole in the side of the sill right at the front, behind the flitch panel on the right hand side. It isn't big and does not go into the floor. The left rear chassis rail where the torsion bar brackets mount has blistering where the double skin is lifting but is not holed. It does need repairing but from experience of repairs to our own car I'm confident it will only be the outer skin so the important location holes will not be lost. Other than that, it's fantastically sound and has not been welded. If only I had found this one before our's I could have saved hundreds of hours of welding. The floors, sills, chassis, suspension mountings, window apertures etc are all good apart from where mentioned. Having spent the past 26 years proffesionally restoring Alfa Romeos, I know exactly what rusty panels look like! If you are about to embark on the restoration of a rough one you will save hours and hours or thousands of pounds if you are paying someone like me to do it. It has its doors and tailgate that are largely sound, a few bits to do and some dents and scrapes. The bonnet is similar although the box section at the bottom has rotted and will need repairing. The wings are a bit battered, being so cheap I'd put new fronts on, the inner wings are fine. I think it would be a shame to break the original factory seal on the the rears and they would staighten up easily. Reading back through this, I'm probably painting a pour picture of how good this is, suffice to say, if you've got an Alfa sprint GT shell in the same condition, I want it! Roger 01760 756229
