As a starting point try some posh 98 octane fuel from a reputable supplier. Check for vacuum hose leaks. Then go for a long run and see if it is better the next day. If not then check all the ignition system. Do anything you can before touching the carburettor.
The carburettors are annoying on those things. The bases warp resulting in a vacuum leak where they connect to the manifold. They can still run OK with a warped base but if the carb is ever removed it will never seal again. Should that be the problem then remove the carb, have the base skimmed flat, buy new gaskets and spacers (there are some improved aftermarket ones around from a webber supplier but I can't find the link so it'll need a google). Bung everything back together then go for a long run to get the carb happy with the new gasket.
I'm guessing it is the 1.7 litre Monaco. If it's the 1.4 litre auto it would be easier as they don't have the carb problem.
