Only trouble is, like an idiot I misdiagnosed my problem!!! Yes, the driveshaft was knackered and very much on its last legs, but that was not what was causing the symptoms. Extensive fiddling over the weekend has now identified the trouble as a broken gearbox mounting, right on the front of the car. Any ideas how I deal with this? The rubber has completely detached causing the gearox and engine to drop down by about 1cm onto a metal flange thingy. Could this have done permanent damage elsewhere? Can I replace the mounting without removing the gearbox? Where can I get a replacement? Liam? Help!!!!
Scruffle
