laxeian
- Earth
Ladyfriend of mine drives a Kangoo, garage she DID use advised her of a waterpump problem, the cure she was given was an engine change and a bill for a €1k, since the swop it has had recurrent overheating problems, the same garage then changed the multi water pipe that runs from header to thermostat housing and radiator.
I have replaced the header tank ( old one split), all replaced jubilee clip at all end on replaced pipe had at least 7 ratchet turns on them to tight, filled and bled and its still leaking fluid, appears to be coming from area of thermostat housing ( which appears new), suspect one pipe from rear of housing to heater matrix ( its a ‘quick fit’ one end of pipe, any advice on how to unclip without damage, or are these one use pipes), or the housing itself, when running I cannot see a leak now, there was leakage from pipes due to jubilee clip, but if I reach under thermostat housing and wipe hand there is dampness to touch
There is no sign of water in oil or visa versa.
When I look at the pipes from thermostat housing to heater matrix I am unsure if they have been connected the correct way round ( the pipes don't sit correctly to my eyes, the top bulkhead pipe goes into bottom thermostat pipe bottom bulkhead into top, so the pipes have a ‘ twist’ where there need not be one, could an unintentional reversal by the ‘ mechanics’ that swapped engine and pipe potentially cause problems?
Any advise or pointers?
